Logitech G915 TKL G1-G8 Key Replacement
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 1 of 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 2 of 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: step 1, image 3 of 3
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: step 2, image 1 of 1
    • Unscrew the front 2mm #00 Phillips screws found here.
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 1 of 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 2 of 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: step 3, image 3 of 3
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: step 4, image 1 of 1
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: step 5, image 1 of 1
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
Brandon Souza
136 Reputation
1 Guide authored
One Comment
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
Magnus - Reply
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 174
All Time: 2,242
