Logitech G915 TKL Keyswitch Replacement
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: step 1, image 1 of 2 Logitech G915 TKL Keyswitch Replacement, Keyswitch: step 1, image 2 of 2
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: step 2, image 1 of 2 Logitech G915 TKL Keyswitch Replacement: step 2, image 2 of 2
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: step 3, image 1 of 2 Logitech G915 TKL Keyswitch Replacement: step 3, image 2 of 2
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: step 4, image 1 of 1
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: step 5, image 1 of 1
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: step 6, image 1 of 1
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
Ethan Bedard
485 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 26
Past 7 Days: 204
Past 30 Days: 1,106
All Time: 10,466
