Logitech MBJ58 Mouse Support Spring Replacement
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: step 1, image 1 of 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Logitech MBJ58 Mouse Support Spring Replacement: step 2, image 1 of 2 Logitech MBJ58 Mouse Support Spring Replacement: step 2, image 2 of 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 1 of 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 2 of 3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 3 of 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: step 4, image 1 of 2 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: step 4, image 2 of 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: step 5, image 1 of 2 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: step 5, image 2 of 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
6 other people completed this guide.
Conor Whatley
489 Reputation
3 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
21 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 3,890
