Logitech UE Boom USB Port Replacement
  1. Logitech UE Boom USB Port Replacement, D-ring: step 1, image 1 of 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom USB Port Replacement: step 2, image 1 of 2 Logitech UE Boom USB Port Replacement: step 2, image 2 of 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom USB Port Replacement, Bluetooth Adapter: step 3, image 1 of 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. Logitech UE Boom USB Port Replacement: step 4, image 1 of 3 Logitech UE Boom USB Port Replacement: step 4, image 2 of 3 Logitech UE Boom USB Port Replacement: step 4, image 3 of 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom USB Port Replacement: step 5, image 1 of 2 Logitech UE Boom USB Port Replacement: step 5, image 2 of 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom USB Port Replacement: step 6, image 1 of 3 Logitech UE Boom USB Port Replacement: step 6, image 2 of 3 Logitech UE Boom USB Port Replacement: step 6, image 3 of 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
  7. Logitech UE Boom USB Port Replacement: step 7, image 1 of 1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. Logitech UE Boom USB Port Replacement, Lithium Battery: step 8, image 1 of 1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. Logitech UE Boom USB Port Replacement: step 9, image 1 of 1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
  10. Logitech UE Boom USB Port Replacement: step 10, image 1 of 3 Logitech UE Boom USB Port Replacement: step 10, image 2 of 3 Logitech UE Boom USB Port Replacement: step 10, image 3 of 3
    • Peel off the sleeve.
  11. Logitech UE Boom USB Port Replacement: step 11, image 1 of 2 Logitech UE Boom USB Port Replacement: step 11, image 2 of 2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. Logitech UE Boom USB Port Replacement: step 12, image 1 of 2 Logitech UE Boom USB Port Replacement: step 12, image 2 of 2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. Logitech UE Boom USB Port Replacement: step 13, image 1 of 2 Logitech UE Boom USB Port Replacement: step 13, image 2 of 2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. Logitech UE Boom USB Port Replacement: step 14, image 1 of 1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. Logitech UE Boom USB Port Replacement: step 15, image 1 of 1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. Logitech UE Boom USB Port Replacement: step 16, image 1 of 2 Logitech UE Boom USB Port Replacement: step 16, image 2 of 2
    • Remove the battery by pulling it from the terminal as marked in the picture.
  17. Logitech UE Boom USB Port Replacement, USB Port: step 17, image 1 of 2 Logitech UE Boom USB Port Replacement, USB Port: step 17, image 2 of 2
    • Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
9 other people completed this guide.
Sean Reilly
1,727 Reputation
2 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
22 Guides authored
12 Comments
Hello,
does anyone know where to get new usb port, the logitech support didnĀ“t really help.
cheers marius
kok0dora94 - Reply
Same question as above, where can i buy a replacement USB port?
Corbett Hix - Reply
i found 10 of them on ebay for 3-4 dollars
johnsonjohnsonalexalex - Reply
Hi there , can you give me a link to Ebay where to find this port, thanks
katiecrow -
can you send me a link on ebay where to find this replacement port , thanks
katiecrow -
Past 24 Hours: 17
Past 7 Days: 75
Past 30 Days: 330
All Time: 32,351
