MacBook Air 11" Mid 2012 Logic Board Replacement
  1. MacBook Air 11" Mid 2012 Logic Board Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 Logic Board Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 Logic Board Replacement, Battery: step 3, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement, Battery: step 3, image 2 of 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 Logic Board Replacement, Solid-State Drive: step 4, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2012 Logic Board Replacement: step 5, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement: step 5, image 2 of 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. MacBook Air 11" Mid 2012 Logic Board Replacement, I/O Board Cable: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
  7. MacBook Air 11" Mid 2012 Logic Board Replacement: step 7, image 1 of 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
  8. MacBook Air 11" Mid 2012 Logic Board Replacement: step 8, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
    • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
    • Remove the I/O board cable.
  9. MacBook Air 11" Mid 2012 Logic Board Replacement, Fan: step 9, image 1 of 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  10. MacBook Air 11" Mid 2012 Logic Board Replacement: step 10, image 1 of 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
  11. MacBook Air 11" Mid 2012 Logic Board Replacement: step 11, image 1 of 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  12. MacBook Air 11" Mid 2012 Logic Board Replacement, Battery: step 12, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  13. MacBook Air 11" Mid 2012 Logic Board Replacement: step 13, image 1 of 1
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  14. MacBook Air 11" Mid 2012 Logic Board Replacement, Logic Board: step 14, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement, Logic Board: step 14, image 2 of 2
    • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  15. MacBook Air 11" Mid 2012 Logic Board Replacement: step 15, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement: step 15, image 2 of 2
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  16. MacBook Air 11" Mid 2012 Logic Board Replacement: step 16, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement: step 16, image 2 of 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  17. MacBook Air 11" Mid 2012 Logic Board Replacement: step 17, image 1 of 1
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  18. MacBook Air 11" Mid 2012 Logic Board Replacement: step 18, image 1 of 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  19. MacBook Air 11" Mid 2012 Logic Board Replacement: step 19, image 1 of 3 MacBook Air 11" Mid 2012 Logic Board Replacement: step 19, image 2 of 3 MacBook Air 11" Mid 2012 Logic Board Replacement: step 19, image 3 of 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
  20. MacBook Air 11" Mid 2012 Logic Board Replacement: step 20, image 1 of 1
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  21. MacBook Air 11" Mid 2012 Logic Board Replacement: step 21, image 1 of 2 MacBook Air 11" Mid 2012 Logic Board Replacement: step 21, image 2 of 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  22. MacBook Air 11" Mid 2012 Logic Board Replacement: step 22, image 1 of 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  23. MacBook Air 11" Mid 2012 Logic Board Replacement: step 23, image 1 of 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  24. MacBook Air 11" Mid 2012 Logic Board Replacement: step 24, image 1 of 1
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
  25. MacBook Air 11" Mid 2012 Logic Board Replacement, Logic Board: step 25, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  26. MacBook Air 11" Mid 2012 Logic Board Replacement: step 26, image 1 of 1
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth board from the logic board.
  27. MacBook Air 11" Mid 2012 Logic Board Replacement: step 27, image 1 of 1
    • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
  28. MacBook Air 11" Mid 2012 Logic Board Replacement: step 28, image 1 of 1
    • If the heat sink seems to be stuck to the logic board after removing all four screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
    • Remove the heat sink from the logic board.
    • Logic board remains.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
26 other people completed this guide.
Andrew Optimus Goldheart
503,578 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,529 Guides authored
2 Comments
Just for your information, this guide is not for the A1465 because the motherboard they are showing is from an A1370. The touchpad and touchpad flex cable are different in both models.
lap tech - Reply
I concur this does not match the A1465 board in some areas. The Airport / Bluetooth connectors are in a different spot and the heatsink is different. Perhaps some photos from another board were used in a few places. The rest appears to be the same, so far.
Digital Oxygen Photography - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 81
All Time: 26,779
