MacBook Air 13" Early 2017 Trackpad Replacement
  1. MacBook Air 13" Early 2017 Trackpad Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2017 Trackpad Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2017 Trackpad Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Early 2017 Trackpad Replacement, Battery Connector: step 3, image 2 of 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2017 Trackpad Replacement, Battery: step 4, image 1 of 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  5. MacBook Air 13" Early 2017 Trackpad Replacement: step 5, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  6. MacBook Air 13" Early 2017 Trackpad Replacement: step 6, image 1 of 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  7. MacBook Air 13" Early 2017 Trackpad Replacement, Trackpad: step 7, image 1 of 3 MacBook Air 13" Early 2017 Trackpad Replacement, Trackpad: step 7, image 2 of 3 MacBook Air 13" Early 2017 Trackpad Replacement, Trackpad: step 7, image 3 of 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
  8. MacBook Air 13" Early 2017 Trackpad Replacement: step 8, image 1 of 2 MacBook Air 13" Early 2017 Trackpad Replacement: step 8, image 2 of 2
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
  9. MacBook Air 13" Early 2017 Trackpad Replacement: step 9, image 1 of 1
    • Remove the following twelve screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • Six 1.6 mm Phillips screws securing the trackpad brackets to the trackpad.
  10. MacBook Air 13" Early 2017 Trackpad Replacement: step 10, image 1 of 1
    • Remove the right and left trackpad brackets from the upper case.
  11. MacBook Air 13" Early 2017 Trackpad Replacement: step 11, image 1 of 1
    • During reassembly, check the clicking action on the trackpad.
    • The 1.4 mm T5 Torx screw near the front edge of the case must be adjusted correctly.
    • If overtightened, the button will cease to click at a certain point. Adjust the set screw until the clicking side of the trackpad has minimal play.
    • It's not necessary to remove this screw in order to remove the trackpad.
  12. MacBook Air 13" Early 2017 Trackpad Replacement: step 12, image 1 of 2 MacBook Air 13" Early 2017 Trackpad Replacement: step 12, image 2 of 2
    • Use the flat end of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
10 other people completed this guide.
Adam O'Camb
197,605 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 49
Past 30 Days: 244
All Time: 12,685
