MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement
Video Overview
  1. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, Battery: step 3, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: step 4, image 1 of 2 MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: step 4, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 5, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 6, image 1 of 2 MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 6, image 2 of 2
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • Remove the AirPort/Bluetooth board from the Air.
10 other people completed this guide.
6 Comments
Which UFL plug is the WIFI one? the one closer to the screw or the other one?
-Majh0l@hush.com
uxa1 - Reply
Dear:
I bought a new A1369 AirPort/Bluetooth Board.When I installing it, I accidentally broken the cable that you were prying at step 4, What can I do?
THx!
Alex - Reply
Which antenna connector is The wi-fi one? The one closest to the screw or the one furthest away?
Joel S - Reply
I would like AC WiFi and Bluetooth 4 support by upgrading the internal card. Can you install upgrade WiFi/Bluetooth cards into this slot?
David Jones - Reply
This guide is helpful but doesn’t include the most important part, which is re-connecting the antennas. I’ve done this exact replacement in my mid-2010 13” MBA, and you will need antenna extenders (MHF4 female to male) to make it work. Other discussions on this suggest breaking off the antenna cable bracket near the hinge to get extra length, but that still won’t work. You need extensions. I found mine on eBay US, despite living in Canada - they didn’t appear on my local site for whatever reason.
Also, be VERY careful when disconnecting the MHF4 connectors from the card (step 4). They’re rated for 30 disconnects max (I had to do a lot of research to find the right connector) and I managed to break one. I essentially had to tape the socket together once I got the extensions in the mail - just buy them from the beginning so you don’t mess around with trying to lengthen to cord like I did. That’s what caused all my issues.
The exact item I bought was “2pcs MHF4 Male to MHF4 Cable Antenna Extension Female.”
peter - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 27
All Time: 29,441
