MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement
  1. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: step 3, image 1 of 3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: step 3, image 2 of 3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
3 other people completed this guide.
Sam Goldheart
466,244 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,437 Guides authored
One Comment
tell me the size of screw driver
nigamyadav56 - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 36
All Time: 10,778
