MacBook Pro 13" Retina Display Late 2013 Fan Replacement
  1. MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 3, image 2 of 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Battery Connector: step 4, image 1 of 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 5, image 2 of 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 6, image 1 of 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Heat Sink: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Heat Sink: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Heat Sink: step 7, image 3 of 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 9, image 1 of 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 10, image 2 of 2
  11. MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Fan: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement, Fan: step 11, image 2 of 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 12, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 12, image 2 of 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 13, image 3 of 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 14, image 1 of 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 15, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 15, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Fan Replacement: step 15, image 3 of 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
43 other people completed this guide.
Sam Goldheart
466,211 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
4 Comments
in step#9, Phillips # 000 screwdriver did not fit in replacing fan?
park changho - Reply
When putting it all back together:
Step 15
Make sure to put the end furthest away from the hinge under the ribbon cable first.
Then place the hinge side. The screw furthest away from the hinge is partially obscured by the ribbon cable.
Step 14 (Part 1)
Start the screws enough to hold the fan in place but don’t tighten them until after step 13.
Step 13
Since the screws are not tight from step 14, putting the fan cable back into the ZIF connector is easier.
Step 14 (Part 2)
Tighten the screws after step 13
Step 12
Continue doing the steps backwards as normal.
toodarkpark - Reply
Should the fan on this machine be on all the time, or only when needed?
Charlie Nancarrow - Reply
Thank you so much
Jack Yuan - Reply
Past 24 Hours: 8
Past 7 Days: 42
Past 30 Days: 168
All Time: 41,619
