MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement
  1. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement, Remove the lower case screws: step 1, image 1 of 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement, Lift the lower case away: step 2, image 1 of 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement, Battery: step 3, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement, Optical Drive: step 4, image 1 of 1
    • Using the flat end of a spudger, gently pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
    • Pry up from beneath the wires.
  5. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 5, image 1 of 1
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  6. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  7. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  8. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 8, image 1 of 1
    • Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
    • The longer of the two screws is on the right.
  9. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 9, image 1 of 2 MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 9, image 2 of 2
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  10. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 10, image 1 of 2 MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 10, image 2 of 2
    • Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case.
    • The right screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  11. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 11, image 1 of 2 MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 11, image 2 of 2
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
  12. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement, Optical Drive: step 12, image 1 of 1
    • Remove the optical drive cable by pulling it straight away from the optical drive.
    • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  13. MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement: step 13, image 1 of 1
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
103 other people completed this guide.
2 Comments
iFixit rocks! Got a stuck CD out of my wife's superdrive this way. Many thanks!!!
Steve Folberg - Reply
I just took mine apart and found a piece of tape in it. Smh. Works perfect now.
Dana Kimble - Reply
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 102
All Time: 154,832
