MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement
  1. MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement, Remove the lower case screws: step 1, image 1 of 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2010 Lower Case Replacement, Lift the lower case away: step 2, image 1 of 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
43 other people completed this guide.
One Comment
Those are actually not seven identical 3 mm screws. The screw located at the ventilation side next to the three 13.5 mm screws does not have a shaft as compared to the other six 3 mm screws.
glaubitz - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 64
All Time: 39,147
