MacBook Pro 13" Unibody Mid 2012 Fan Replacement
  1. MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 Fan Replacement: step 2, image 1 of 2 MacBook Pro 13" Unibody Mid 2012 Fan Replacement: step 2, image 2 of 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Battery Connection: step 3, image 1 of 2 MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Battery Connection: step 3, image 2 of 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Mid 2012 Fan Replacement: step 4, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Fan: step 5, image 1 of 3 MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Fan: step 5, image 2 of 3 MacBook Pro 13" Unibody Mid 2012 Fan Replacement, Fan: step 5, image 3 of 3
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Mid 2012 Fan Replacement: step 6, image 1 of 1
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Mid 2012 Fan Replacement: step 7, image 1 of 1
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
174 other people completed this guide.
Andrew Optimus Goldheart
503,355 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,432 Guides authored
7 Comments
Repair done as presented. The fan connection was a little tricky to get out but apart from that non eventful. New fan working nicely.
Paul Lukabyo - Reply
Hi! Thank you for very understandable and good guides!
After successfully changing the fan and battery in my Mac, the screen light changes from time to time, sometimes it is more yellow and sometimes it is more blue. Have I accidentally changed some cable, or what it is that could have happened?
Many thanks,
Maja
Maja - Reply
You described the colors very well, and that leads me to believe that your display preferences in the System Preferences Control Panel may simply have switched to automatic. It changes the hues to what they think are easier on the eyes for day and night. Go to
“Apple Menu”
“System Preferences” (it’s also in the Dock by default)
“Displays”
“Night Shift”
and adjust it the way you like. BTW, if it seems to be happening at times other than Sunrise and Sunset, make sure the Time Zone is set for your local area and proper Daylight Savings (if applicable) or Standard Time.
Good Luck,
Beowulf
Beowulf Grendel -
Thanks, job done nicely
Ahmed Mahran - Reply
my fan wont work with the back cover installed, i replaced, and again it doesnt stay working, if i tap the case sometimes it starts when using macs fan control full blast
A S - Reply
Past 24 Hours: 13
Past 7 Days: 64
Past 30 Days: 305
All Time: 91,557
