MacBook Pro 15" Retina Display Late 2013 Feet Replacement
  1. MacBook Pro 15" Retina Display Late 2013 Feet Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 2, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 2, image 2 of 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 3, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 3, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 3, image 3 of 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Late 2013 Feet Replacement, Feet: step 4, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Feet Replacement, Feet: step 4, image 2 of 2
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  5. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 5, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  6. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 6, image 1 of 1
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  7. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 7, image 1 of 1
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  8. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 8, image 1 of 1
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  9. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 9, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 9, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 9, image 3 of 3
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • You may want to use a pencil to lightly mark where the alignment nub is located. Be careful not to scratch the lower case with your pencil.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  10. MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 10, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 Feet Replacement: step 10, image 2 of 2
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
21 other people completed this guide.
Taylor Dixon
67,391 Reputation
94 Guides authored
One Comment
Just finished doing the feet replacement (using the iFixit replacement parts) on a late-2013 15 inch Retina MacBook Pro and it was just a perfect result. Thank you for this great guide.
Rafael Pérez - Reply
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 153
All Time: 14,475
