MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement
  1. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement: step 2, image 1 of 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement, Battery Connector: step 3, image 1 of 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement: step 4, image 1 of 2 MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement: step 4, image 2 of 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement, I/O Board Cable: step 5, image 1 of 3 MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement, I/O Board Cable: step 5, image 2 of 3 MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement, I/O Board Cable: step 5, image 3 of 3
    • Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
    • In a similar fashion, remove the I/O board cable from its socket on the I/O board.
  6. MacBook Pro 15" Retina Display Late 2013 I/O Board Cable Replacement: step 6, image 1 of 1
    • Remove the I/O board cable from the MacBook Pro.
2 other people completed this guide.
Andrew Optimus Goldheart
503,411 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,462 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 6,592
