MacBook Unibody Model A1342 Lower Case Replacement
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: step 2, image 1 of 3 MacBook Unibody Model A1342 Lower Case Replacement: step 2, image 2 of 3 MacBook Unibody Model A1342 Lower Case Replacement: step 2, image 3 of 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
74 other people completed this guide.
2 Comments
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Reply
Would the Macbook Pro back cover also fit this?
wow - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 48
All Time: 69,769
