Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement
  1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement, Joystick: step 1, image 1 of 1
    • Unplug your controller from your console or pc.
  2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 2, image 1 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 2, image 2 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 2, image 3 of 3
    • Remove the four 3mm screws with a Philips #0 screwdriver.
  3. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 3, image 1 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 3, image 2 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 3, image 3 of 3
    • Remove the six 0.9mm screws with a Phillips #00 screwdriver.
  4. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 4, image 1 of 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 4, image 2 of 2
    • Remove the metal plate cover.
    • Find the lever inside of the controller.
  5. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 5, image 1 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 5, image 2 of 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 5, image 3 of 3
    • Insert your Flathead screwdriver into the middle of the lever to hold it in place.
    • Twist the ball to remove it from the lever.
    • Remove the ball top from the lever.
  6. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 6, image 1 of 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 6, image 2 of 2
    • Remove the four 1.1mm screws holding the lever in place with your Phillips #0 screwdriver.
  7. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 7, image 1 of 1
    • Remove the lever from the casing of the controller.
  8. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 8, image 1 of 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: step 8, image 2 of 2
    • Pull the cable connected to the lever out of the socket.
    • Remove the lever from the case.
Jordan
184 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 19
Past 7 Days: 142
Past 30 Days: 217
All Time: 1,787
