Mantis Tiller 7566 2017 Carburetor Assembly Replacement
  1. Mantis Tiller 7566 2017 Carburetor Assembly Replacement, Carburetor Assembly: step 1, image 1 of 2 Mantis Tiller 7566 2017 Carburetor Assembly Replacement, Carburetor Assembly: step 1, image 2 of 2
    • Remove the air filter cover.
  2. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: step 2, image 1 of 2 Mantis Tiller 7566 2017 Carburetor Assembly Replacement: step 2, image 2 of 2
    • Remove two 5/16 standard nuts under the air cover.
    • Remove the last two bolts pictured with a 5/32 Allen wrench.
    • Note the order you remove the bolts. The top is usually longer than the bottom.
  3. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: step 3, image 1 of 2 Mantis Tiller 7566 2017 Carburetor Assembly Replacement: step 3, image 2 of 2
    • Remove old carburetor and install the new one. Remove the throttle cable and reinstall with needle nose pliers. Tighten throttle cable to carb part #16100-Z0Z-034
  4. Mantis Tiller 7566 2017 Carburetor Assembly Replacement: step 4, image 1 of 1
    • Reassemble and test throttle.
6 other people completed this guide.
Trevor A
1,339 Reputation
6 Guides authored
One Comment
whats the part number
ROGELIO - Reply
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 154
All Time: 1,661
