Video Overview
This teardown is not a repair guide. To repair your Meta Quest Pro, use our service manual.
  1. Meta Quest Pro Chip ID, Headset Mainboard Side A: step 1, image 1 of 1
  2. Meta Quest Pro Chip ID: step 2, image 1 of 1
    • Infineon CYPD3177 USB Type-C Port Controller
    • Qualcomm SMB1355 Li-Ion Battery Charger w/ Quick Charge 2.0/3.0/5.0
    • Qualcomm PM3003A Power Management
    • Texas Instruments TLC59401 16-Ch. LED Driver
    • Texas Instruments TS3USB221 USB 2.0 SPDT Analog Switch
    • Awinic AW37504CSR ? Dual Output Power Supply
    • Analog Devices MAX77827B 1.6 A Buck Boost Converter
  3. Meta Quest Pro Chip ID: step 3, image 1 of 1
    • Texas Instruments TPS62148 2.0 A step-down converter
    • Texas Instruments TPS61378-Q1 4.8 A synchronous boost converter
    • SG Micro SGM66056 2.2 MHz synchronous boost converter
    • OmniVision WS4694C 28 V over-voltage & over-current protection load switch
    • SG Micro SGM2578AAD 2 A load switch
    • Texas Instruments TLV7031 single comparator
    • Texas Instruments TLV9054 quad 5-MHz rail-to-rail operational amplifier
  4. Meta Quest Pro Chip ID: step 4, image 1 of 1
    • SG Micro SGM4T245 4-Bit Bus Transceiver
    • SG Micro SGM2045-1.20 300 mA / 1.2 V LDO regulator
    • SG Micro SGM2045-3.00 300 mA / 3.00 V LDO regulator
    • Nexperia 74AUP3G34 triple buffer
    • Nexperia 74LVC1G07 single buffer
    • NXP Semiconductor NX30P0121UK 3 A over-voltage protection
    • Awinic AW32710CSR over-voltage protection load switch
  5. Meta Quest Pro Chip ID: step 5, image 1 of 1
    • onsemi FSA4480UCX USB Type-C analog switch
    • SG Micro SGM4553 2-bit bidirectional voltage-level translator
    • OmniVision DPDT analog switch (possibly)
  6. Meta Quest Pro Chip ID, Headset Mainboard Side B: step 6, image 1 of 1
    • Murata LBEE5xx1WK ? type 1WK Bluetooth/WiFi module
    • Nordic Semiconductor nRF52840 Bluetooth 5.3 low-energy SoC
    • Qualcomm PM8250 power management
    • Qualcomm PM8150B power management
    • Qualcomm PMK8002 ? clock generator
    • Texas Instruments TCA6418E 18-bit I/O expander
    • Renesas SLG59M1717V 5 A load switch
  7. Meta Quest Pro Chip ID: step 7, image 1 of 1
    • Likely Texas Instruments LP5907UVE-1.2 250 mA / 1.2 V LDO regulator
    • DC-DC converter
  8. Meta Quest Pro Chip ID, Headset Mainboard Side B - Sensors: step 8, image 1 of 1
    • Bosch Sensortec BMM150 3-axis magnetometer
  9. Meta Quest Pro Chip ID, Controller Mainboard Side A: step 9, image 1 of 2 Meta Quest Pro Chip ID, Controller Mainboard Side A: step 9, image 2 of 2
    • Qualcomm SM6115 Snapdragon 662 Octa-Core applications/baseband processor
    • Samsung K4U8E3S4AD-MGCL 1 GB LPDDR4X SDRAM memory
    • Samsung KLM4G1FETE-B041 4 GB eMMC NAND flash memory
    • Qualcomm PMI632 power management
    • Microchip ATSAMD20G17 32-bit microcontroller
    • Renesas DA7281 haptic driver
    • Texas Instruments SN74AUC1G32 single 2-input OR gate
  10. Meta Quest Pro Chip ID: step 10, image 1 of 1
    • Nexperia PUSB3FR4 4 ch. ESD protection
  11. Meta Quest Pro Chip ID, Controller Mainboard Side A - Sensors: step 11, image 1 of 1
    • TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope
    • Allegro MicroSystems A1392 hall effect sensor
    • Allegro MicroSystems A1395 hall effect sensor
  12. Meta Quest Pro Chip ID, Controller Mainboard Side B: step 12, image 1 of 2 Meta Quest Pro Chip ID, Controller Mainboard Side B: step 12, image 2 of 2
    • Qualcomm PM4250 power management
    • Cirrus Logic CS40L25 haptic driver
    • Nexperia 74LV1T34 single translating buffer
    • Nexperia 74LV1T04 single translating inverter
  13. Meta Quest Pro Chip ID, Controller Mainboard Side B - Radio: step 13, image 1 of 1
    • Nordic Semiconductor nRF52832 Bluetooth Low-Energy 5.3 SoC
    • Skyworks SKY66111-11 Bluetooth Low Energy front-end module
    • Probably Qorvo QPC8019Q DPDT RF switch
    • Qualcomm WCN3950 WLAN 802.11a/b/g/n/ac, Bluetooth 5.0, & FM radio
  14. Meta Quest Pro Chip ID, Controller Mainboard Side B - Sensors: step 14, image 1 of 1
    • Allegro MicroSystems A1391 hall effect sensor
  15. Meta Quest Pro Chip ID, Console Accelerometer Board: step 15, image 1 of 1
    • TDK-InvenSense ICM-42688-P 6-axis MEMS accelerometer & gyroscope
  16. Meta Quest Pro Chip ID, Headset Mainboard Side B: step 16, image 1 of 1
    • Cmedia CM7120 Audio DSP & CODEC Hub
    • Analog Devices MAX98360A Class-D Audio Amplifier
    • Qualcomm SMB1355 Battery Charger
  17. Meta Quest Pro Chip ID, Headset Block Diagram: step 17, image 1 of 1
    • Predicted block diagram primarily based on available datasheets and observed implementation in product.
  18. Meta Quest Pro Chip ID, Controller Block Diagram: step 18, image 1 of 1
One Comment
Any photo-and-text-based teardown of the entire device like iFixit used to do? Love the company, but the fact that there aren't non-video articles on this under the Teardowns section is honestly a bit of a letdown. Would it be possible to bring them back? They're a really useful resource.
Ethan Zuo - Reply
Past 24 Hours: 4
Past 7 Days: 81
Past 30 Days: 346
All Time: 6,717
