Microsoft Surface 2 Speaker Replacement
  1. Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 1 of 3 Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 2 of 3 Microsoft Surface 2 Speaker Replacement, Screen: step 1, image 3 of 3
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2 Speaker Replacement: step 2, image 1 of 3 Microsoft Surface 2 Speaker Replacement: step 2, image 2 of 3 Microsoft Surface 2 Speaker Replacement: step 2, image 3 of 3
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
  3. Microsoft Surface 2 Speaker Replacement, Speaker: step 3, image 1 of 2 Microsoft Surface 2 Speaker Replacement, Speaker: step 3, image 2 of 2
    • Work close to Magnetic Project Map to avoid losing screws.
    • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
    • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
    • Once all screws have been removed, lift and remove the bezel from the rest of the device.
  4. Microsoft Surface 2 Speaker Replacement: step 4, image 1 of 1
    • Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
  5. Microsoft Surface 2 Speaker Replacement: step 5, image 1 of 2 Microsoft Surface 2 Speaker Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the cable connecting the speaker to the motherboard.
    • Peel up the tiny strip of yellow tape securing the cable to the motherboard.
  6. Microsoft Surface 2 Speaker Replacement: step 6, image 1 of 2 Microsoft Surface 2 Speaker Replacement: step 6, image 2 of 2
    • Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
EG1
597 Reputation
2 Guides authored
USF Tampa, Team 3-1, Wollert Spring 2016 Member of USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,267
