Microsoft Surface Book 2 15" Battery Replacement
  1. Microsoft Surface Book 2 15" Battery Replacement, Motherboard: step 1, image 1 of 1
    • Open the laptop, then orient it towards yourself.
    • Count from the bottom up by six holes on the tablet portion of the laptop.
  2. Microsoft Surface Book 2 15" Battery Replacement: step 2, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 2, image 2 of 2
    • Take a paper clip and unfold it.
    • Place the paperclip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
  3. Microsoft Surface Book 2 15" Battery Replacement: step 3, image 1 of 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
  4. Microsoft Surface Book 2 15" Battery Replacement: step 4, image 1 of 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
  5. Microsoft Surface Book 2 15" Battery Replacement: step 5, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 5, image 2 of 2
    • Lift up the screen.
    • Detach the ribbon cables connected from the screen to the motherboard on the underside of the screen.
  6. Microsoft Surface Book 2 15" Battery Replacement: step 6, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement: step 6, image 2 of 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
  7. Microsoft Surface Book 2 15" Battery Replacement: step 7, image 1 of 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
  8. Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: step 8, image 1 of 2 Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: step 8, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Use an iOpener or a heat gun (on low heat) to carefully heat the back side of the tablet to help soften the battery adhesive.
    • Use prying tools such as a guitar pick, plastic card, or a nylon spudger to help sever the adhesive, and gently lift the battery free.
    • After the case cools, a careful amount of isopropyl alcohol can help dissolve stubborn glue between the battery and the case.
    • Work slowly and carefully. Do not pry, bend, or puncture the battery while removing it from the tablet.
2 other people completed this guide.
Ryan Picewick
468 Reputation
4 Guides authored
3 Comments
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
Nicholas Law - Reply
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
darth mango -
I also find it rather confusing.
Thanks darth mango.
Past 24 Hours: 34
Past 7 Days: 179
Past 30 Days: 1,000
All Time: 8,624
