Microsoft Surface Laptop 3 13.5" Screen Replacement
  1. Microsoft Surface Laptop 3 13.5" Screen Replacement, Prepare your device: step 1, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Prepare your device: step 1, image 2 of 2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 13.5" Screen Replacement, Flip the laptop over: step 2, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Flip the laptop over: step 2, image 2 of 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 13.5" Screen Replacement, Removal tip: step 3, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Removal tip: step 3, image 2 of 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the rear feet: step 4, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the rear feet: step 4, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the rear feet: step 4, image 3 of 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the front feet: step 5, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the front feet: step 5, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the front feet: step 5, image 3 of 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 6, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 6, image 2 of 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 7, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 7, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 7, image 3 of 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the upper case screws: step 8, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 13.5" Screen Replacement, Open the display: step 9, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Open the display: step 9, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Open the display: step 9, image 3 of 3
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 13.5" Screen Replacement, Lift up the upper case: step 10, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Lift up the upper case: step 10, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Lift up the upper case: step 10, image 3 of 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 13.5" Screen Replacement, Disconnect the ribbon cable: step 11, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Disconnect the ribbon cable: step 11, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Disconnect the ribbon cable: step 11, image 3 of 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the upper case: step 12, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the upper case: step 12, image 2 of 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the SSD screw: step 13, image 1 of 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the SSD: step 14, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the SSD: step 14, image 2 of 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  15. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the display connector shields: step 15, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the display connector shields: step 15, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the display connector shields: step 15, image 3 of 3
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Repeat at different points around the shield until it becomes loose.
    • Remove the shield.
  16. Microsoft Surface Laptop 3 13.5" Screen Replacement: step 16, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement: step 16, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement: step 16, image 3 of 3
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
  17. Microsoft Surface Laptop 3 13.5" Screen Replacement, Disconnect the display cables: step 17, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Disconnect the display cables: step 17, image 2 of 2
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
  18. Microsoft Surface Laptop 3 13.5" Screen Replacement: step 18, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement: step 18, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement: step 18, image 3 of 3
    • Disconnect the three remaining display connectors.
  19. Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 19, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Reassembly tip: step 19, image 2 of 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
  20. Microsoft Surface Laptop 3 13.5" Screen Replacement, Tilt open the screen: step 20, image 1 of 1
    • Open the screen as far as it will go.
  21. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove four hinge screws: step 21, image 1 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove four hinge screws: step 21, image 2 of 3 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove four hinge screws: step 21, image 3 of 3
    • When removing the hinge screws, make sure to hold the screen steady as it will become more and more loose as the hinge screws are gradually removed.
    • While holding the screen steady, use a T6 Torx driver to remove the four outermost 5.9 mm screws securing the screen, two on each side.
    • Leave the two innermost hinge screws in place for now, one on each side.
  22. Microsoft Surface Laptop 3 13.5" Screen Replacement, Tilt the screen vertical: step 22, image 1 of 1
    • Slowly tilt the screen until it's approximately vertical.
    • During reassembly, with the first two hinge screws tightened in place, the screen is free to tilt open for installation of the remaining four hinge screws.
  23. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the final hinge screws: step 23, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the final hinge screws: step 23, image 2 of 2
    • While holding the screen steady, use a T6 Torx driver to remove the two remaining 5.9 mm screws securing the screen, one on each side.
    • With these two final screws removed the screen will be freed from the rest of the device, so hold it steady.
    • If the screen is exactly perpendicular to the lower case, a screwdriver handle may contact the display during removal. If you're having trouble, lightly tilt the screen back enough to clear the driver.
  24. Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the screen: step 24, image 1 of 2 Microsoft Surface Laptop 3 13.5" Screen Replacement, Remove the screen: step 24, image 2 of 2
    • Lift the screen straight up and off of the lower case to remove it.
    • During reassembly, ensure the replacement screen's hinges are at a 90 degree angle with the display.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
2 other people completed this guide.
Carsten Frauenheim
115,370 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
One Comment
Where can I find a spare display?
Abdullah Rayhan - Reply
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 158
All Time: 3,947
