Microsoft Surface Pro 5 Screen Replacement
  1. Careful: steps 1-22 are sourced from a guide that's marked as in-progress.
    Microsoft Surface Pro 5 Screen Replacement, Heat the screen: step 1, image 1 of 1
    • Completely power off the Surface before you begin disassembly.
    • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
  2. Microsoft Surface Pro 5 Screen Replacement, Take note of the adhesive layout: step 2, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement, Take note of the adhesive layout: step 2, image 2 of 2
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
  3. Microsoft Surface Pro 5 Screen Replacement, Insert an opening pick into the speaker opening: step 3, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement, Insert an opening pick into the speaker opening: step 3, image 2 of 2
    • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
  4. Microsoft Surface Pro 5 Screen Replacement, Slide an opening pick under the screen: step 4, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement, Slide an opening pick under the screen: step 4, image 2 of 2
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
  5. Microsoft Surface Pro 5 Screen Replacement, Cut through the screen adhesive: step 5, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement, Cut through the screen adhesive: step 5, image 2 of 2
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  6. Microsoft Surface Pro 5 Screen Replacement: step 6, image 1 of 1
    • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
  7. Microsoft Surface Pro 5 Screen Replacement: step 7, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 7, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 7, image 3 of 3
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  8. Microsoft Surface Pro 5 Screen Replacement: step 8, image 1 of 1
    • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
  9. Microsoft Surface Pro 5 Screen Replacement: step 9, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 9, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 9, image 3 of 3
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  10. Microsoft Surface Pro 5 Screen Replacement: step 10, image 1 of 1
    • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
  11. Microsoft Surface Pro 5 Screen Replacement: step 11, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 11, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 11, image 3 of 3
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
  12. Microsoft Surface Pro 5 Screen Replacement: step 12, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 12, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 12, image 3 of 3
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
  13. Microsoft Surface Pro 5 Screen Replacement: step 13, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 13, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 13, image 3 of 3
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
  14. Microsoft Surface Pro 5 Screen Replacement, Open the Surface: step 14, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement, Open the Surface: step 14, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement, Open the Surface: step 14, image 3 of 3
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
  15. Microsoft Surface Pro 5 Screen Replacement: step 15, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 15, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 15, image 3 of 3
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
  16. Microsoft Surface Pro 5 Screen Replacement, Disconnect the screen: step 16, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement, Disconnect the screen: step 16, image 2 of 2
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Repeat this procedure at different points around the shield until it is free.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
  17. Microsoft Surface Pro 5 Screen Replacement: step 17, image 1 of 1
    • Lift the EMI shield away from the display board and remove it.
  18. Microsoft Surface Pro 5 Screen Replacement: step 18, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 18, image 2 of 2
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
  19. Microsoft Surface Pro 5 Screen Replacement: step 19, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 19, image 2 of 2
    Tool used on this step:
    Buy
    • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
    • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  20. Microsoft Surface Pro 5 Screen Replacement: step 20, image 1 of 1
    • Pull the rest of the shield off of the digitizer connector and remove it.
  21. Microsoft Surface Pro 5 Screen Replacement: step 21, image 1 of 2 Microsoft Surface Pro 5 Screen Replacement: step 21, image 2 of 2
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
  22. Microsoft Surface Pro 5 Screen Replacement: step 22, image 1 of 1
    • Remove the screen assembly from the Surface.
    • During reassembly, pause here and follow this guide to replace the screen adhesive.
  23. Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: step 23, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: step 23, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement, Disconnect the display board: step 23, image 3 of 3
    • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
  24. Microsoft Surface Pro 5 Screen Replacement: step 24, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement: step 24, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement: step 24, image 3 of 3
    Buy
    • Use tweezers to slide the display cables straight out of their sockets on the display board.
  25. Microsoft Surface Pro 5 Screen Replacement, Remove the display board: step 25, image 1 of 3 Microsoft Surface Pro 5 Screen Replacement, Remove the display board: step 25, image 2 of 3 Microsoft Surface Pro 5 Screen Replacement, Remove the display board: step 25, image 3 of 3
    • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
  26. Microsoft Surface Pro 5 Screen Replacement: step 26, image 1 of 1
    Tesa 61395 Tape
    $5.99
    Buy
    • Remove the display board.
    • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
    • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
  27. Microsoft Surface Pro 5 Screen Replacement: step 27, image 1 of 1
    • Only the screen remains.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
39 other people completed this guide.
Sam Omiotek
73,693 Reputation
288 Guides authored
5 Comments
These instructions are very detailed. I followed them exactly. For the most part, they are great. Unfortunately, I bricked the original screen during removal process. After successfully removing the old screen without damaging the glass, I noticed that I had cut through one of the LCD screen connectors at the bottom left of the screen. The ifixit instructions on screen removal depicts this area as a "safe zone". It states "these areas only contain adhesive and are safe to cut." It does mention to avoid inserting the removal pick beyond the black screen bezel. Unfortunately, wires to the LCD screen, at least on my screen, extended a few mm into the black bezel area and were damaged by the removal pick. Therefore, the lower edge of the screen is not completely a "safe zone". Since the adhesive does not extend beyond about half way into the black bezel, I would recommend not inserting the pick more than half way into the black bezel, at least along the bottom edge.
Angelo Petropolis - Reply
I just had the same experience :(
Dmitry Matiouchenko - Reply
Moin, kann mir einer sagen, wo ich einen guten ersatz bildschirm für das 7 pro bekomme. die range geht ja von 84 bis weit über 400euro. hatte 1 aus italien für 104 gekauft, da geht der touch nicht und es wird gelegentlich dunkel und dann später geht es wieder und am unterern rand gibt es verfärbungen, je wärmer es ist ? wer billig kauft kauf 2x. nur wer sagt das die 400 euro display nicht auch mist sind....
Bo Chris Zen - Reply
Great instructions. Just finished the 7 hour replacement successfully. Original screen was removed without damage aside from one lcd screen connector on bottom left corner (Mentioned in earlier comments). Watch this area. Very very easy to ruin these cables.
Cameron - Reply
As the previous commenters say, DO NOT INSERT THE PICK MORE THAN HALF WAY NEAR WHERE THE RIBBON CABLES ARE! Roll the pick here, just as where the antennas are.
Bill - Reply
Past 24 Hours: 19
Past 7 Days: 180
Past 30 Days: 737
All Time: 47,384
