Microsoft Surface Pro 6 Kickstand Replacement
  1. Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: step 1, image 1 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: step 1, image 2 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Open the kickstand: step 1, image 3 of 3
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: step 2, image 1 of 2 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand screws: step 2, image 2 of 2
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: step 3, image 1 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: step 3, image 2 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Close the kickstand: step 3, image 3 of 3
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: step 4, image 1 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: step 4, image 2 of 3 Microsoft Surface Pro 6 Kickstand Replacement, Remove the kickstand: step 4, image 3 of 3
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
7 other people completed this guide.
Sarah Westberg
23,465 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
7 Comments
Any way to replace the hinges themself?
Only-Wonder - Reply
Also trying to find this out.
Bobby Stephenson -
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
Chris Goodluck - Reply
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
Arthur Shi -
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
zsugahill - Reply
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 190
All Time: 21,319
