Microsoft Surface Pro 7 Kickstand Replacement
  1. Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: step 1, image 1 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: step 1, image 2 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Open the kickstand: step 1, image 3 of 3
    • Lift the kickstand to expose the hinge screws.
  2. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: step 2, image 1 of 2 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand screws: step 2, image 2 of 2
    • Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
  3. Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: step 3, image 1 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: step 3, image 2 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Close the kickstand: step 3, image 3 of 3
    • Move the kickstand back down to a flat position.
    • The hinges are stiff and you may need to use some force to get it down.
  4. Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: step 4, image 1 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: step 4, image 2 of 3 Microsoft Surface Pro 7 Kickstand Replacement, Remove the kickstand: step 4, image 3 of 3
    • Remove the kickstand from the back cover.
    • There are two adhesive tabs in the middle of the kickstand that disengage most easily when the kickstand is pulled directly downward from the device.
    • Be sure to insert these tabs when reinstalling the new kickstand before replacing the screws.
Sam Omiotek
73,693 Reputation
288 Guides authored
2 Comments
One of the hinges broke on my Surface Pro 6.
1. I removed the broken hinge, closed the kickstand and duct taped the seam.
2. I opened the kickstand wide and duct taped the seam.
The single hinge and duct tape seem to be working!
"Spare the duct tape, spoil the job." - Red Green
P Best - Reply
What are the parts used for this fix?
Andrea Shaw - Reply
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 198
All Time: 6,638
