Microsoft Zune HD Controls Sidebar Replacement
  1. Microsoft Zune HD Controls Sidebar Replacement, Upper Rear Panel: step 1, image 1 of 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Controls Sidebar Replacement: step 2, image 1 of 2 Microsoft Zune HD Controls Sidebar Replacement: step 2, image 2 of 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: step 3, image 1 of 2 Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: step 3, image 2 of 2
    • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
    • Try not excessively rotate the media button lever about this post.
One Comment
Can the side panels (hello from Seattle) come off as well?
Evoke - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 3,126
