Mitsubishi Diamondpoint NXM76LCD Display Replacement
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 3 of 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 2, image 1 of 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 3 of 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 4, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 4, image 2 of 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 5, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 5, image 2 of 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: step 6, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: step 6, image 2 of 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 3 of 3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: step 8, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: step 8, image 2 of 2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: step 9, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: step 9, image 2 of 2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 3 of 3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 11, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 11, image 2 of 2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: step 12, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: step 12, image 2 of 2
    • Remember to plug in all the cables on the display.
Padraic Hoselton
4,180 Reputation
12 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,483 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 19
All Time: 169
