Motorola Moto G5 Front Camera Replacement
  1. Motorola Moto G5 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Back Cover: step 1, image 2 of 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Front Camera Replacement: step 2, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 2, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 2, image 3 of 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Front Camera Replacement: step 3, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 3, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 3, image 3 of 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Front Camera Replacement: step 4, image 1 of 2 Motorola Moto G5 Front Camera Replacement: step 4, image 2 of 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Front Camera Replacement, Battery: step 5, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Battery: step 5, image 2 of 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Front Camera Replacement: step 6, image 1 of 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: step 7, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: step 7, image 2 of 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Front Camera Replacement: step 8, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 8, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 8, image 3 of 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Front Camera Replacement: step 9, image 1 of 3 Motorola Moto G5 Front Camera Replacement: step 9, image 2 of 3 Motorola Moto G5 Front Camera Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Front Camera Replacement, Motherboard: step 10, image 1 of 1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Front Camera Replacement: step 11, image 1 of 1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Front Camera Replacement: step 12, image 1 of 1
    Buy
    • Unplug the back connector from the motherboard using tweezers.
  13. Motorola Moto G5 Front Camera Replacement, Front Camera: step 13, image 1 of 2 Motorola Moto G5 Front Camera Replacement, Front Camera: step 13, image 2 of 2
    Buy
    • Grab the connector with the tweezers and gently unplug the front camera from the motherboard.
4 other people completed this guide.
Enosh Reeder
209 Reputation
1 Guide authored
Cal Poly, Team S2-G3, Livingston Winter 2018 Member of Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,959
