Motorola Moto G5 Motherboard Replacement
  1. Motorola Moto G5 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G5 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Motherboard Replacement: step 2, image 1 of 3 Motorola Moto G5 Motherboard Replacement: step 2, image 2 of 3 Motorola Moto G5 Motherboard Replacement: step 2, image 3 of 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Motherboard Replacement: step 3, image 1 of 3 Motorola Moto G5 Motherboard Replacement: step 3, image 2 of 3 Motorola Moto G5 Motherboard Replacement: step 3, image 3 of 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Motherboard Replacement: step 4, image 1 of 2 Motorola Moto G5 Motherboard Replacement: step 4, image 2 of 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Motherboard Replacement, Battery: step 5, image 1 of 2 Motorola Moto G5 Motherboard Replacement, Battery: step 5, image 2 of 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Motherboard Replacement: step 6, image 1 of 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: step 7, image 1 of 2 Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: step 7, image 2 of 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Motherboard Replacement: step 8, image 1 of 3 Motorola Moto G5 Motherboard Replacement: step 8, image 2 of 3 Motorola Moto G5 Motherboard Replacement: step 8, image 3 of 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Motherboard Replacement: step 9, image 1 of 3 Motorola Moto G5 Motherboard Replacement: step 9, image 2 of 3 Motorola Moto G5 Motherboard Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Motherboard Replacement: step 11, image 1 of 1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Motherboard Replacement: step 12, image 1 of 1
    Buy
    • Unplug the back connector from the motherboard using tweezers.
11 other people completed this guide.
Luis Garcia
307 Reputation
1 Guide authored
Cal Poly, Team S2-G3, Livingston Winter 2018 Member of Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Members
16 Guides authored
2 Comments
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - Reply
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 48
All Time: 6,236
