Motorola Moto G5 Vibration Motor Replacement
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: step 1, image 1 of 2 Motorola Moto G5 Vibration Motor Replacement, Back Cover: step 1, image 2 of 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: step 2, image 1 of 3 Motorola Moto G5 Vibration Motor Replacement: step 2, image 2 of 3 Motorola Moto G5 Vibration Motor Replacement: step 2, image 3 of 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: step 3, image 1 of 3 Motorola Moto G5 Vibration Motor Replacement: step 3, image 2 of 3 Motorola Moto G5 Vibration Motor Replacement: step 3, image 3 of 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: step 4, image 1 of 2 Motorola Moto G5 Vibration Motor Replacement: step 4, image 2 of 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: step 5, image 1 of 2 Motorola Moto G5 Vibration Motor Replacement, Battery: step 5, image 2 of 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: step 6, image 1 of 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: step 7, image 1 of 1
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: step 8, image 1 of 1
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: step 9, image 1 of 3 Motorola Moto G5 Vibration Motor Replacement: step 9, image 2 of 3 Motorola Moto G5 Vibration Motor Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: step 10, image 1 of 1
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: step 11, image 1 of 1
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
7 other people completed this guide.
Miles Cobb
370 Reputation
1 Guide authored
Cal Poly, Team S2-G3, Livingston Winter 2018 Member of Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Members
16 Guides authored
One Comment
Is this also where the mic is located?
Matt - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 20
All Time: 3,400
