New Nintendo 2DS XL Circle Pad Replacement
  1. New Nintendo 2DS XL Circle Pad Replacement, Back Cover Removal Preparation: step 1, image 1 of 1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. New Nintendo 2DS XL Circle Pad Replacement, Back Cover Removal: step 2, image 1 of 1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Circle Pad Replacement, Case Separation: step 3, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Case Separation: step 3, image 2 of 2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Circle Pad Replacement: step 4, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 4, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: step 5, image 2 of 2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: step 6, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: step 6, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: step 6, image 3 of 3
    • To more easily access this ribbon cable, flip the device so the back casing faces upwards. Gently slide the back casing forward, revealing the ribbon cable connecting to the motherboard.
    • Using a spudger, pry up the ZIF connector holding the ribbon cable.
    • Pull the ribbon towards the bottom casing and out of the connector.
  7. New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: step 7, image 1 of 2 New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: step 7, image 2 of 2
    • Remove the two 7.5mm phillips screws using a PH000 screwdriver.
    • Gently flip over the circle pad. Be aware that the pad is pressed into the back of the circle pad on the front of the case. Gentle prying will be necessary to pry if from the back of the circle pad.
    • Be aware that there is a black plastic disc that sits between the circle pad module and the circle pad stick. During reassembly, stand the unit on end and hang the plastic disc on the circle pad module and hold the stick from the front to press them back together.
  8. New Nintendo 2DS XL Circle Pad Replacement: step 8, image 1 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 8, image 2 of 3 New Nintendo 2DS XL Circle Pad Replacement: step 8, image 3 of 3
    • Using a spudger, lift up the ZIF connector (the hinge is located on the side closest to where the cable connects).
    • Remove the circle pad by pulling it away from the connector.
5 other people completed this guide.
Tim Newman
1,633 Reputation
4 Guides authored
Cal Poly, Team S18-G6, Forte Fall 2017 Member of Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Members
20 Guides authored
3 Comments
I can’t seem to find a New 2ds XL circle pad replacement online, does anyone know if a regular 2ds circle pad works? (Or perhaps a 3ds one?)
Dvdcd - Reply
Future Myself, the 3ds circle pad kinda works. The major change here is the screw holes, they were moved in on the 2ds xl, so if you do some sanding and finagling it will work, but it’s not elegant at all.
Dvdcd -
Excellent guide, although I believe the 2ds XL requires a Y00 and not a Y0
Gabrielle Watson - Reply
Past 24 Hours: 6
Past 7 Days: 60
Past 30 Days: 289
All Time: 13,036
