New Nintendo 2DS XL Top Screen Replacement
  1. New Nintendo 2DS XL Top Screen  Replacement, Back Cover Removal Preparation: step 1, image 1 of 1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. New Nintendo 2DS XL Top Screen  Replacement, Back Cover Removal: step 2, image 1 of 1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Top Screen  Replacement, Case Separation: step 3, image 1 of 2 New Nintendo 2DS XL Top Screen  Replacement, Case Separation: step 3, image 2 of 2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Top Screen  Replacement: step 4, image 1 of 3 New Nintendo 2DS XL Top Screen  Replacement: step 4, image 2 of 3 New Nintendo 2DS XL Top Screen  Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Top Screen  Replacement, Battery Removal: step 5, image 1 of 2 New Nintendo 2DS XL Top Screen  Replacement, Battery Removal: step 5, image 2 of 2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. New Nintendo 2DS XL Top Screen  Replacement, Disconnect Top Screen: step 6, image 1 of 3 New Nintendo 2DS XL Top Screen  Replacement, Disconnect Top Screen: step 6, image 2 of 3 New Nintendo 2DS XL Top Screen  Replacement, Disconnect Top Screen: step 6, image 3 of 3
    Buy
    • Release the top screen ribbon cable in image 1. Thread it through the rectangular slot below the tweezers.
    • Carefully coil the ribbon cable and prepare to slide it through the cylinder hinge.
  7. New Nintendo 2DS XL Top Screen  Replacement, Remove Plastic Plate: step 7, image 1 of 2 New Nintendo 2DS XL Top Screen  Replacement, Remove Plastic Plate: step 7, image 2 of 2
    • Remove the two screws holding the plastic cover plate down to reveal the red wifi wire which will come out along with the top screen and case.
  8. New Nintendo 2DS XL Top Screen  Replacement, Disconnect Wi-fi Antenna: step 8, image 1 of 2 New Nintendo 2DS XL Top Screen  Replacement, Disconnect Wi-fi Antenna: step 8, image 2 of 2
    • Disconnect the wifi wire and unclip it along its path around the battery tray and under the plastic plate we removed before.
    • Slide out the cylinder that holds the other side of the hinge together.
    • On my 2DS XL, I wiggled the top half of the case and the cylinder wiggled out enough to grab it with the tweezers.
  9. New Nintendo 2DS XL Top Screen  Replacement, Remove Top Screen and Shell: step 9, image 1 of 2 New Nintendo 2DS XL Top Screen  Replacement, Remove Top Screen and Shell: step 9, image 2 of 2
    • Finish sliding the ribbon cable through the hinge and free the red wifi wire, as well.
    • The top part of the case is now free, and you are okay to set the rest of the 2DS XL aside for reassembly.
    • I apologize for the quality of the picture, but as you can see, the cable slides through a slot on the top case's hinge body. carefully slide the cable out of the slot and free the cable from the two pins holding it down to the case frame.
  10. New Nintendo 2DS XL Top Screen  Replacement, Remove Plastic Plate: step 10, image 1 of 3 New Nintendo 2DS XL Top Screen  Replacement, Remove Plastic Plate: step 10, image 2 of 3 New Nintendo 2DS XL Top Screen  Replacement, Remove Plastic Plate: step 10, image 3 of 3
    • Insert a spudger along the edge of the plastic plate on the top shell. Pry up gently until the glue releases. There is a large glue pad under this plate, but there is nothing else holding it on.
    • After prying off the plate, there are four screws marked in the rings to release the back plate from the screen plate.
    • Once the screws are removed, lift off the back plate to reveal the screen and plastic trim.
  11. New Nintendo 2DS XL Top Screen  Replacement, Separate Screen and Bezel: step 11, image 1 of 3 New Nintendo 2DS XL Top Screen  Replacement, Separate Screen and Bezel: step 11, image 2 of 3 New Nintendo 2DS XL Top Screen  Replacement, Separate Screen and Bezel: step 11, image 3 of 3
    • Gently pry around the top edge of the case. As you can see, my case is cracked, but not as a result of this repair. This plastic is very thin, so do be careful working your way around the case.
    • The front lens is plastic, but it is held to the frame with glue pads. Using multiple soft tools, work your way around the lens to free the lens and the screen from the frame bezel.
    • You can now set aside the bezel for reassembly.
  12. New Nintendo 2DS XL Top Screen  Replacement, Remove Screen from Lens: step 12, image 1 of 1
    • Because the lens is plastic, I gently bent the lens away from the screen to release it. Using a spudger or pry tool will also be very useful here.
    • Once you have removed the screen, you are ready to replace the screen and begin reassembly.
    • Be very mindful of the ribbon cable as it goes back through the hinge during reassembly, as it can be damaged very easily.
24 other people completed this guide.
Chris Julian
994 Reputation
1 Guide authored
11 Comments
I think there is a missing step between step 5 and 6. I followed the instructions until step 5, but couldn’t figure out how to separate the top case from the bottom case. In step 6, you can see the top case has been separated from the bottom case. But no instruction is given on how to do that.
David Lin - Reply
The hinge only has one component holding it together from coming apart. It is on the left hi he as you look at it like you're playing. The hinge component is a small barrel that resides inside the hinge. You have to open and close it while it is on its right side and try to grab with a pair of tweezers onto the edge of the barrel.
Chris Julian - Reply
Didn’t follow exactly how to disconnect the top section fully.
Brian Shuler - Reply
Hopefully I can assist you. Where are you getting stuck? The barrel on the left hinge is a bit difficult to remove. I opened and closed the hinge a few times with the left hinge up off the desk. While doing this, I watched for the edge of the barrel to poke out so I could grab it with angled tweezers. That was the hardest part of removing the top half for me personally, but it is almost exactly like the DSi XL, and I have disassembled many of those already. My kids are NOT gentle with electronics.
After getting the barrel out on the left hinge, coil up the ribbon cable around the wifi antenna and slide it through the right side of the hollow hinge.
Chris Julian -
Does this work with the pokeball edition of the 2ds?
DocWhoGaming - Reply
Past 24 Hours: 30
Past 7 Days: 275
Past 30 Days: 1,194
All Time: 50,298
