Nexus 9 LCD Screen Replacement
  1. Nexus 9 LCD Screen Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 LCD Screen Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 LCD Screen Replacement, Rear Case: step 1, image 3 of 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 LCD Screen Replacement, Front Facing Camera: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
  3. Nexus 9 LCD Screen Replacement, Battery: step 3, image 1 of 2 Nexus 9 LCD Screen Replacement, Battery: step 3, image 2 of 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  4. Nexus 9 LCD Screen Replacement: step 4, image 1 of 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  5. Nexus 9 LCD Screen Replacement: step 5, image 1 of 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  6. Nexus 9 LCD Screen Replacement: step 6, image 1 of 1
    • The battery should now lift free of the tablet.
  7. Nexus 9 LCD Screen Replacement, Antenna Board: step 7, image 1 of 2 Nexus 9 LCD Screen Replacement, Antenna Board: step 7, image 2 of 2
    • This step is not necessary if you have already removed the battery.
  8. Nexus 9 LCD Screen Replacement: step 8, image 1 of 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  9. Nexus 9 LCD Screen Replacement: step 9, image 1 of 1
    Buy
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
  10. Nexus 9 LCD Screen Replacement, Speakers: step 10, image 1 of 1
    • Use a spudger or your fingers to remove the first speaker. The speaker may be heavily glued in and require heat to lift. Be careful as you can pull the speaker apart.
  11. Nexus 9 LCD Screen Replacement: step 11, image 1 of 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  12. Nexus 9 LCD Screen Replacement: step 12, image 1 of 2 Nexus 9 LCD Screen Replacement: step 12, image 2 of 2
    Buy
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  13. Nexus 9 LCD Screen Replacement: step 13, image 1 of 3 Nexus 9 LCD Screen Replacement: step 13, image 2 of 3 Nexus 9 LCD Screen Replacement: step 13, image 3 of 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  14. Nexus 9 LCD Screen Replacement: step 14, image 1 of 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  15. Nexus 9 LCD Screen Replacement: step 15, image 1 of 1
    • Use a spudger to remove the second speaker.
  16. Nexus 9 LCD Screen Replacement, Vibrator: step 16, image 1 of 2 Nexus 9 LCD Screen Replacement, Vibrator: step 16, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the vibrator from the device.
  17. Nexus 9 LCD Screen Replacement, Motherboard: step 17, image 1 of 2 Nexus 9 LCD Screen Replacement, Motherboard: step 17, image 2 of 2
    • Remove the three 3 mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
  18. Nexus 9 LCD Screen Replacement: step 18, image 1 of 2 Nexus 9 LCD Screen Replacement: step 18, image 2 of 2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
  19. Nexus 9 LCD Screen Replacement: step 19, image 1 of 1
    • Gently lift the motherboard up from the device.
  20. Nexus 9 LCD Screen Replacement: step 20, image 1 of 1
  21. Nexus 9 LCD Screen Replacement, USB Daughterboard: step 21, image 1 of 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
  22. Nexus 9 LCD Screen Replacement, LCD Screen: step 22, image 1 of 2 Nexus 9 LCD Screen Replacement, LCD Screen: step 22, image 2 of 2
    • Use a spudger or your fingers to remove the LCD connector from the display assembly.
  23. Nexus 9 LCD Screen Replacement: step 23, image 1 of 2 Nexus 9 LCD Screen Replacement: step 23, image 2 of 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  24. Nexus 9 LCD Screen Replacement: step 24, image 1 of 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • Always wait at least three minutes before reheating the iOpener.
  25. Nexus 9 LCD Screen Replacement: step 25, image 1 of 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  26. Nexus 9 LCD Screen Replacement: step 26, image 1 of 2 Nexus 9 LCD Screen Replacement: step 26, image 2 of 2
    • Place the iOpener on the sides of the LCD where the adhesive is located beneath.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
    • This should be repeated for every side of the tablet, and each side will most likely need to be heated more than once.
  27. Nexus 9 LCD Screen Replacement: step 27, image 1 of 3 Nexus 9 LCD Screen Replacement: step 27, image 2 of 3 Nexus 9 LCD Screen Replacement: step 27, image 3 of 3
    • Using the picks located in the iOpener Kit, insert the picks into the corners of the tablet, and move it back and forth along the sides of tablet.
    • Do this for every corner of the tablet until it is possible to pull the LCD from the display assembly with your finger.
    • Carefully remove the LCD from the display assembly because there is a ribbon located at the bottom that could be ripped with force.
    • The LCD should come completely free from the back assembly now by just leading the ribbon through the opening in the display assembly.
6 other people completed this guide.
Kelsey Rodriguez
874 Reputation
2 Guides authored
Cal Poly, Team 19-11, Maness Winter 2015 Member of Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Members
7 Guides authored
2 Comments
What if the glass is broken and the lcd seems fine? Can I just get a new piece of glass and do the heating/pick steps?
Weston S - Reply
So I replaced the lcd abd glass but it won't display any thing when I turn it on I get haptic feedback and the led turns on but nothing on the screen I plugged it in and no battery charging display either I checked yto make sure the screen was not damaged in anyway what could be the problem ? I followed your guied to the letter ???
kanif88 - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 14,646
