Nexus 9 Vibrator Replacement
  1. Nexus 9 Vibrator Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Vibrator Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Vibrator Replacement, Rear Case: step 1, image 3 of 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Vibrator Replacement, Vibrator Daughterboard: step 2, image 1 of 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 Vibrator Replacement: step 3, image 1 of 2 Nexus 9 Vibrator Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 Vibrator Replacement: step 4, image 1 of 3 Nexus 9 Vibrator Replacement: step 4, image 2 of 3 Nexus 9 Vibrator Replacement: step 4, image 3 of 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 Vibrator Replacement: step 5, image 1 of 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 Vibrator Replacement, Vibrator: step 6, image 1 of 2 Nexus 9 Vibrator Replacement, Vibrator: step 6, image 2 of 2
    Buy
    • Use a pair of tweezers to remove the vibrator from the device.
Geoff Wacker
90,127 Reputation
89 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 322
