Nintendo 2DS Battery Replacement
  1. Nintendo 2DS Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: step 2, image 1 of 2 Nintendo 2DS Battery Replacement: step 2, image 2 of 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: step 3, image 1 of 3 Nintendo 2DS Battery Replacement: step 3, image 2 of 3 Nintendo 2DS Battery Replacement: step 3, image 3 of 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
33 other people completed this guide.
Fina Beauchamp
3,030 Reputation
6 Guides authored
Cal Poly, Team 70-1, Forte Winter 2015 Member of Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Members
35 Guides authored
5 Comments
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Reply
This didnt help my problem
Artemy Matveev - Reply
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Reply
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Reply
Past 24 Hours: 31
Past 7 Days: 154
Past 30 Days: 686
All Time: 41,310
