Introduction
Replacing the touchscreen assembly is difficult because it requires removing the motherboard. Don't take this task on lightly. There are many delicate ribbon cables, so be careful and go slow. The home button is held in by the touchscreen assembly. Be sure not to lose that assembly.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Locate the joystick assembly near the top right corner of the motherboard.
Remove the two 8mm Phillips #00 screws from the back of the joystick.
Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
Locate the gamecard reader near the bottom right corner of the motherboard.
Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
Remove the power cable, indicated by the black and red wires, by gently pulling it up and out of the connector.
Gently pull the ribbon cables out of the 4 ZIF connectors.
Lift the retaining tab and remove the large ribbon cable on the left side of the motherboard.
Lift the retaining tab and remove the large ribbon cable on the top of the motherboard behind the infrared receiver.
Lift the retaining tab and remove the large ribbon cable on the top of the motherboard just above the joysitck housing.
Pry the tab just left of the joystick housing until the right corner of the touchscreen is free.
Pry the top of the touchscreen gently until the top middle and left side of the touchscreen is free.
3 other people completed this guide.
2 Comments
I followed instructions but now the 3DS wont turn on, black screens with a blue light the turns off after about 20 - 30 seconds
i opened up again and saw 3 zif connectors were not closed flush, not sure if this is the problem. If it i how do you go about replacing them?
