Introduction
Replace the Wi-Fi board in your 3DS so you can get back on the Nintendo eShop.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
14 other people completed this guide.
8 Comments
will a 3ds xl wireless card fit within a 3ds? I am on Ebay looking to buy a replacement part but i can't find a proper replacement.
Hi David, i know this is an older guide, but you just saved me from buying a new 3DS. The wifi board had come lose in a drop, with your help i managed to reattach it and bring it back into working condition.
Thank you!
