Nintendo GameCube Front and Back Panel Replacement
  1. Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 1 of 3 Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 2 of 3 Nintendo GameCube Front and Back Panel Replacement, Top Case: step 1, image 3 of 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Front and Back Panel Replacement: step 2, image 1 of 3 Nintendo GameCube Front and Back Panel Replacement: step 2, image 2 of 3 Nintendo GameCube Front and Back Panel Replacement: step 2, image 3 of 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: step 3, image 1 of 1
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Front and Back Panel Replacement: step 4, image 1 of 1
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: step 5, image 1 of 2 Nintendo GameCube Front and Back Panel Replacement, Separate the casing: step 5, image 2 of 2
    • This step may not be necessary depending on your end goal
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
4 other people completed this guide.
dcarlin
301 Reputation
4 Guides authored
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Members
45 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 149
All Time: 14,464
