Nintendo GameCube Top Case Replacement
  1. Nintendo GameCube Top Case Replacement, Top Case: step 1, image 1 of 3 Nintendo GameCube Top Case Replacement, Top Case: step 1, image 2 of 3 Nintendo GameCube Top Case Replacement, Top Case: step 1, image 3 of 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Top Case Replacement: step 2, image 1 of 3 Nintendo GameCube Top Case Replacement: step 2, image 2 of 3 Nintendo GameCube Top Case Replacement: step 2, image 3 of 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
13 other people completed this guide.
dcarlin
301 Reputation
4 Guides authored
Cal Poly, Team 6-2, Maness Fall 2009 Member of Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Members
45 Guides authored
One Comment
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - Reply
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 156
All Time: 24,669
