Nintendo Wii Faceplate Replacement
  1. Nintendo Wii Faceplate Replacement, Faceplate: step 1, image 1 of 2 Nintendo Wii Faceplate Replacement, Faceplate: step 1, image 2 of 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Faceplate Replacement: step 2, image 1 of 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Faceplate Replacement: step 3, image 1 of 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Faceplate Replacement: step 4, image 1 of 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Faceplate Replacement: step 5, image 1 of 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Faceplate Replacement: step 6, image 1 of 2 Nintendo Wii Faceplate Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
23 other people completed this guide.
3 Comments
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - Reply
Tanks for this guide Btw
Kyrre - Reply
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - Reply
Past 24 Hours: 6
Past 7 Days: 55
Past 30 Days: 335
All Time: 53,674
