Nintendo Wii Remote Motherboard Replacement
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Motherboard Replacement: step 2, image 1 of 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: step 3, image 1 of 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: step 4, image 1 of 2 Nintendo Wii Remote Motherboard Replacement: step 4, image 2 of 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: step 5, image 1 of 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: step 6, image 1 of 2 Nintendo Wii Remote Motherboard Replacement: step 6, image 2 of 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
28 other people completed this guide.
Emily
1,584 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
26 Guides authored
7 Comments
Where do you find a motherboard and how much do they typically cost?
Jeff - Reply
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Reply
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Reply
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Reply
Past 24 Hours: 14
Past 7 Days: 80
Past 30 Days: 298
All Time: 31,605
