Nintendo Wii Remote Sensor Screen Replacement
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: step 1, image 1 of 2 Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: step 1, image 2 of 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Sensor Screen Replacement: step 2, image 1 of 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Sensor Screen Replacement: step 3, image 1 of 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Sensor Screen Replacement: step 4, image 1 of 2 Nintendo Wii Remote Sensor Screen Replacement: step 4, image 2 of 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: step 5, image 1 of 3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: step 5, image 2 of 3 Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: step 5, image 3 of 3
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
12 other people completed this guide.
Emily
1,584 Reputation
6 Guides authored
Cal Poly, Team 3-44, Amido Spring 2013 Member of Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Members
26 Guides authored
2 Comments
Where can the screen be purchased??
cutsiepie6480 - Reply
how is this moderate difficulty
Sqwerks - Reply
Past 24 Hours: 12
Past 7 Days: 51
Past 30 Days: 227
All Time: 20,673
