Nintendo Wii U Button Replacement
  1. Nintendo Wii U Button Replacement, Button Replacement: step 1, image 1 of 2 Nintendo Wii U Button Replacement, Button Replacement: step 1, image 2 of 2
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: step 2, image 1 of 1
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: step 3, image 1 of 2 Nintendo Wii U Button Replacement: step 3, image 2 of 2
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: step 4, image 1 of 3 Nintendo Wii U Button Replacement: step 4, image 2 of 3 Nintendo Wii U Button Replacement: step 4, image 3 of 3
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: step 5, image 1 of 3 Nintendo Wii U Button Replacement: step 5, image 2 of 3 Nintendo Wii U Button Replacement: step 5, image 3 of 3
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: step 6, image 1 of 3 Nintendo Wii U Button Replacement: step 6, image 2 of 3 Nintendo Wii U Button Replacement: step 6, image 3 of 3
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: step 7, image 1 of 1
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: step 8, image 1 of 1
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: step 9, image 1 of 1
    • Remove the desired button(s).
Emily Vasquez
884 Reputation
3 Guides authored
USF Tampa, Team 1-2, Leahy Spring 2016 Member of USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 Members
13 Guides authored
One Comment
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 73
All Time: 4,558
