Nintendo Wii U Console Outer Case Replacement
  1. Nintendo Wii U Console Outer Case Replacement, Console Outer Case: step 1, image 1 of 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Console Outer Case Replacement: step 2, image 1 of 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Console Outer Case Replacement: step 3, image 1 of 2 Nintendo Wii U Console Outer Case Replacement: step 3, image 2 of 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Console Outer Case Replacement: step 4, image 1 of 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Console Outer Case Replacement: step 5, image 1 of 3 Nintendo Wii U Console Outer Case Replacement: step 5, image 2 of 3 Nintendo Wii U Console Outer Case Replacement: step 5, image 3 of 3
    • On the back of the console, lift up and release the main top cover.
27 other people completed this guide.
Kim Arre
4,918 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
39 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 74
Past 30 Days: 321
All Time: 32,558
