Nokia Lumia 2520 Charging connection Replacement
  1. Nokia Lumia 2520 Charging connection  Replacement, Display Assembly: step 1, image 1 of 1
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
  2. Nokia Lumia 2520 Charging connection  Replacement: step 2, image 1 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 2, image 2 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 2, image 3 of 3
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
    • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
  3. Nokia Lumia 2520 Charging connection  Replacement: step 3, image 1 of 2 Nokia Lumia 2520 Charging connection  Replacement: step 3, image 2 of 2
    • Pull the ribbon cable out from the connection port on the board.
    • Move on the step 4 to remove the ribbon connection from the screen.
  4. Nokia Lumia 2520 Charging connection  Replacement: step 4, image 1 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 4, image 2 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 4, image 3 of 3
    • Use the plastic pry tool to remove both of the connections.
  5. Nokia Lumia 2520 Charging connection  Replacement: step 5, image 1 of 1
    • Set aside the screen and the display assembly for repair.
  6. Nokia Lumia 2520 Charging connection  Replacement, Battery: step 6, image 1 of 3 Nokia Lumia 2520 Charging connection  Replacement, Battery: step 6, image 2 of 3 Nokia Lumia 2520 Charging connection  Replacement, Battery: step 6, image 3 of 3
    • Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid.
    • Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case.
    • Use a plastic pry tool to remove the battery connector from the logic board.
  7. Nokia Lumia 2520 Charging connection  Replacement: step 7, image 1 of 2 Nokia Lumia 2520 Charging connection  Replacement: step 7, image 2 of 2
    • Remove the ribbon located over the battery.
  8. Nokia Lumia 2520 Charging connection  Replacement: step 8, image 1 of 1
    • Theres four screws that attach the battery to the chassis. Use a PH0 Phillips head screwdriver to loosen the screw.
    • Since the tool using is sharp please use with caution, so that you don't puncture the battery.
  9. Nokia Lumia 2520 Charging connection  Replacement: step 9, image 1 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 9, image 2 of 3 Nokia Lumia 2520 Charging connection  Replacement: step 9, image 3 of 3
    • Take a plastic pry to to pry out the battery from its casing.
    • The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok .
    • Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
  10. Nokia Lumia 2520 Charging connection  Replacement, Charging connection: step 10, image 1 of 3 Nokia Lumia 2520 Charging connection  Replacement, Charging connection: step 10, image 2 of 3 Nokia Lumia 2520 Charging connection  Replacement, Charging connection: step 10, image 3 of 3
    • Take a pry tool and remove the connection.
    • Take a pry tool and push away the charing connector from its housing.
    • The adhesive is very strong so use a lot of force.
Degan Berhe
614 Reputation
4 Guides authored
Gateway, Team S1-G4, Luster Fall 2018 Member of Gateway, Team S1-G4, Luster Fall 2018
GCC-LUSTER-F18S1G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 671
