Opening Philips Sonicare without damaging it
  1. Opening Philips Sonicare without damaging it, Opening Philips Sonicare without damaging it: step 1, image 1 of 2 Opening Philips Sonicare without damaging it, Opening Philips Sonicare without damaging it: step 1, image 2 of 2
    • The basic idea: A suitable machine screw is screwed into the hole on the bottom cover.
  2. Opening Philips Sonicare without damaging it: step 2, image 1 of 2 Opening Philips Sonicare without damaging it: step 2, image 2 of 2
    • First measure the diameter of the hole, this one here is 5.3 mm.
    • Now look for a slightly larger machine screw. In this case something with a diameter of 6.2 mm. You possibly may also find one among non-metric screws.
  3. Opening Philips Sonicare without damaging it: step 3, image 1 of 2 Opening Philips Sonicare without damaging it: step 3, image 2 of 2
    • Now turn the screw into the hole. It will cut its own thread and it will get quite tight. If it gets too tight, the cover may eventually break, so be careful.
  4. Opening Philips Sonicare without damaging it: step 4, image 1 of 2 Opening Philips Sonicare without damaging it: step 4, image 2 of 2
    • Then you can pull the cover off by hand with a lot of force and feeling. Good luck!
    • Here you can clearly see the two clamps that hold the innards in place. Those must be compressed when removing the cover.
    • It is advisable to also replace the seal on the drive at the same time. If it leaks, moisture will get into the device. Look closely at the seal, there are two different types.
    • The housing can be cleaned with descaler for coffee machines. Grease the seals with food-grade silicone grease.
Work through the steps in reverse order to reassemble your device.
9 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
205,513 Reputation
250 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,152 Guides authored
7 Comments
Thank you very much! The trick with using a screw to remove the bottom lid was amazing.
Adrian - Reply
Congrats! I'm glad that I could help.
VauWeh -
yes, thank you for the tip to use a screw. it was really difficult and resorted to also using some metal spudgers and lucky I didn’t jab my hands (pro tip: put some leather work gloves on!)
another pro tip I learned from a YouTube video, is to take wire cutters and snip off the 2 clips that make it so difficult to get this thing off.
there is enough friction at play that the clips are not needed and you can just pull out the assembly much easier in the future.
Chinarut - Reply
That worked absolutely fine for me. I used a 8 thread tap to prepare the hole and then an M8x70mm screw to pull out.
Duenengeist - Reply
Danke, deine Anleitung hat geholfen. Jetzt vibriert die Zahnbürste wieder schön. ich hab den Spalt zwischen dem Magneten und dem Motor etwas erweitert. Leider musste ich feststellen, das die weiße Dichtung oben eingerissen ist. Kannst du mir sagen , wo ich so eine Dichtung bekommen kann?
Johannes Preissinger - Reply
Past 24 Hours: 56
Past 7 Days: 379
Past 30 Days: 1,882
All Time: 16,615
