Panasonic Toughbook CF-29 Back Cover Replacement
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: step 1, image 1 of 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: step 2, image 1 of 2 Panasonic Toughbook CF-29 Back Cover Replacement: step 2, image 2 of 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: step 3, image 1 of 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: step 4, image 1 of 1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: step 5, image 1 of 2 Panasonic Toughbook CF-29 Back Cover Replacement: step 5, image 2 of 2
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: step 6, image 1 of 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: step 7, image 1 of 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: step 8, image 1 of 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: step 9, image 1 of 2 Panasonic Toughbook CF-29 Back Cover Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: step 10, image 1 of 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: step 11, image 1 of 1
    • Now the back cover should be off and you can access the inside of the casing.
3 other people completed this guide.
Rohun Heesen
426 Reputation
2 Guides authored
Cal Poly, Team 27-93, Amido Spring 2010 Member of Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Members
26 Guides authored
One Comment
thanks for this crucial tuatorial >
Joe Gutierrez - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 10,065
