PlayStation 3 Slim Laser lens Replacement
ZFix
ZFix and 3 other contributors
Last updated on July 13, 2024
45 minutes
Moderate
Community-Contributed Guide
Introduction
Go to step 1
Video tutorial - how to replace Laser Lens only:
Tools
Show more…
Video Overview
  1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: step 1, image 1 of 2 PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: step 1, image 2 of 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  2. PlayStation 3 Slim Laser lens Replacement: step 2, image 1 of 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  3. PlayStation 3 Slim Laser lens Replacement: step 3, image 1 of 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  4. PlayStation 3 Slim Laser lens Replacement: step 4, image 1 of 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  5. PlayStation 3 Slim Laser lens Replacement: step 5, image 1 of 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  6. PlayStation 3 Slim Laser lens Replacement: step 6, image 1 of 2 PlayStation 3 Slim Laser lens Replacement: step 6, image 2 of 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
20 other people completed this guide.
ZFix
194,093 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,699 Guides authored
5 Comments
Donde puedo comprar refacciones y partes para PS3 Slim?
David - Reply
yo vendo amigo = ivaramso@gmail.com para ventas
Ivan Ramirez -
How can this be easy, but the Blu-Ray drive be considered Moderate? You need to complete the Blu-Ray drive removal prior to replacing the laser lens, which means this is at best a Moderate task.
Ben Kevan - Reply
This is not lens replacement, this is drive replacement. Is there a separate guide for lens replacement?
cmchallam - Reply
Shows how to do the laser assembly in the video but not how to reinstall it in the drive. Lazy guide. Just buy a whole new drive if you are following this guide.
Beninja - Reply
Past 24 Hours: 10
Past 7 Days: 32
Past 30 Days: 130
All Time: 34,234
