PlayStation 5 Fan Replacement
  1. PlayStation 5 Fan Replacement, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Fan Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 Fan Replacement, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Fan Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 Fan Replacement, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 Fan Replacement, Cap the screw hole: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Fan Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 Fan Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 Fan Replacement, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Fan Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 Fan Replacement, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 1 of 3 PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 2 of 3 PlayStation 5 Fan Replacement, Remove the right faceplate: step 7, image 3 of 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Fan Replacement: step 8, image 1 of 2 PlayStation 5 Fan Replacement: step 8, image 2 of 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 1 of 3 PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 2 of 3 PlayStation 5 Fan Replacement, Pry up the grille: step 9, image 3 of 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Fan Replacement, Remove the grille: step 10, image 1 of 2 PlayStation 5 Fan Replacement, Remove the grille: step 10, image 2 of 2
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Fan Replacement, Remove the fan shroud screws: step 11, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Fan Replacement, Remove the fan shroud: step 12, image 1 of 2 PlayStation 5 Fan Replacement, Remove the fan shroud: step 12, image 2 of 2
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 1 of 3 PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 2 of 3 PlayStation 5 Fan Replacement, Remove the wire cover: step 13, image 3 of 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Fan Replacement: step 14, image 1 of 3 PlayStation 5 Fan Replacement: step 14, image 2 of 3 PlayStation 5 Fan Replacement: step 14, image 3 of 3
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Fan Replacement, Disconnect the fan: step 15, image 1 of 2 PlayStation 5 Fan Replacement, Disconnect the fan: step 15, image 2 of 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Fan Replacement, Remove the fan: step 16, image 1 of 3 PlayStation 5 Fan Replacement, Remove the fan: step 16, image 2 of 3 PlayStation 5 Fan Replacement, Remove the fan: step 16, image 3 of 3
    • Lift the fan up and out of the case to remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
31 other people completed this guide.
Robert Boyd
26,762 Reputation
94 Guides authored
6 Comments
Hello, I followed tronix fixs and he used pliers then I used it as well and the yellow part came off and the fan lines broke I don't know what to do since I have been saving up since it came out
Emran - Reply
Can I put a 23 blade fan in a system that came with the 1.9a 17 blade fan?
wgeclipse - Reply
Did you find out?
Popes -
I just did exactly that for a customer (technically it was a 23 blade 2.15A fan) it works great, the fan connector leads are just barely long enough to fit in the channel in a CFI-1215A model though, so careful not to tug too hard after plugging the fan connector and seating the fan in place.
just chris... -
Would a fan going bad prevent the PS 5 from turning on?
Frank Garcia - Reply
Past 24 Hours: 219
Past 7 Days: 1,794
Past 30 Days: 7,500
All Time: 156,352
