PlayStation 5 LED Board Replacement
  1. PlayStation 5 LED Board Replacement, Remove the stand screw: step 1, image 1 of 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 LED Board Replacement, Remove the vertical stand: step 2, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the vertical stand: step 2, image 2 of 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 LED Board Replacement, Store the stand screw: step 3, image 1 of 2 PlayStation 5 LED Board Replacement, Store the stand screw: step 3, image 2 of 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 LED Board Replacement, Cap the screw hole: step 4, image 1 of 3 PlayStation 5 LED Board Replacement, Cap the screw hole: step 4, image 2 of 3 PlayStation 5 LED Board Replacement, Cap the screw hole: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 LED Board Replacement, Close the cubby: step 5, image 1 of 3 PlayStation 5 LED Board Replacement, Close the cubby: step 5, image 2 of 3 PlayStation 5 LED Board Replacement, Close the cubby: step 5, image 3 of 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 LED Board Replacement, Remove the horizontal stand: step 6, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the horizontal stand: step 6, image 2 of 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 LED Board Replacement, Remove the right faceplate: step 7, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the right faceplate: step 7, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the right faceplate: step 7, image 3 of 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 LED Board Replacement: step 8, image 1 of 2 PlayStation 5 LED Board Replacement: step 8, image 2 of 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 LED Board Replacement, Pry up the grille: step 9, image 1 of 3 PlayStation 5 LED Board Replacement, Pry up the grille: step 9, image 2 of 3 PlayStation 5 LED Board Replacement, Pry up the grille: step 9, image 3 of 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 LED Board Replacement, Remove the grille: step 10, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the grille: step 10, image 2 of 2
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 LED Board Replacement, Remove the fan shroud screws: step 11, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 LED Board Replacement, Remove the fan shroud: step 12, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the fan shroud: step 12, image 2 of 2
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 LED Board Replacement, Remove the wire cover: step 13, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the wire cover: step 13, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the wire cover: step 13, image 3 of 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 LED Board Replacement: step 14, image 1 of 3 PlayStation 5 LED Board Replacement: step 14, image 2 of 3 PlayStation 5 LED Board Replacement: step 14, image 3 of 3
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 LED Board Replacement, Disconnect the fan: step 15, image 1 of 2 PlayStation 5 LED Board Replacement, Disconnect the fan: step 15, image 2 of 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 LED Board Replacement, Remove the fan: step 16, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the fan: step 16, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the fan: step 16, image 3 of 3
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 LED Board Replacement, Remove the SSD cover: step 17, image 1 of 1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 LED Board Replacement: step 18, image 1 of 3 PlayStation 5 LED Board Replacement: step 18, image 2 of 3 PlayStation 5 LED Board Replacement: step 18, image 3 of 3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 LED Board Replacement, Remove the optical drive wire: step 19, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the optical drive wire: step 19, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 LED Board Replacement: step 20, image 1 of 2 PlayStation 5 LED Board Replacement: step 20, image 2 of 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: step 21, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: step 21, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the tamper-evident sticker: step 21, image 3 of 3
    Buy
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 LED Board Replacement, Remove the case screws: step 22, image 1 of 1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 LED Board Replacement, Remove the case: step 23, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the case: step 23, image 2 of 2
    • Lift the case straight up to remove it.
  24. PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 24, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 24, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 24, image 3 of 3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 LED Board Replacement, Remove the optical drive: step 25, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the optical drive: step 25, image 2 of 2
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 26, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 26, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the optical drive ribbon cable: step 26, image 3 of 3
    Buy
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. PlayStation 5 LED Board Replacement, Remove the power and eject button ribbon cable: step 27, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the power and eject button ribbon cable: step 27, image 2 of 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. PlayStation 5 LED Board Replacement, Remove the LED ribbon cable: step 28, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the LED ribbon cable: step 28, image 2 of 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. PlayStation 5 LED Board Replacement, Remove the antenna wires: step 29, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the antenna wires: step 29, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the antenna wires: step 29, image 3 of 3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. PlayStation 5 LED Board Replacement: step 30, image 1 of 3 PlayStation 5 LED Board Replacement: step 30, image 2 of 3 PlayStation 5 LED Board Replacement: step 30, image 3 of 3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. PlayStation 5 LED Board Replacement, Remove the white stickers: step 31, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the white stickers: step 31, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the white stickers: step 31, image 3 of 3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. PlayStation 5 LED Board Replacement: step 32, image 1 of 3 PlayStation 5 LED Board Replacement: step 32, image 2 of 3 PlayStation 5 LED Board Replacement: step 32, image 3 of 3
    • Repeat the previous step to peel back the four remaining stickers.
  33. PlayStation 5 LED Board Replacement: step 33, image 1 of 3 PlayStation 5 LED Board Replacement: step 33, image 2 of 3 PlayStation 5 LED Board Replacement: step 33, image 3 of 3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. PlayStation 5 LED Board Replacement, Remove the top shield plate screws: step 34, image 1 of 1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. PlayStation 5 LED Board Replacement, Remove the top shield plate: step 35, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the top shield plate: step 35, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the top shield plate: step 35, image 3 of 3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. PlayStation 5 LED Board Replacement, Disconnect the USB board: step 36, image 1 of 3 PlayStation 5 LED Board Replacement, Disconnect the USB board: step 36, image 2 of 3 PlayStation 5 LED Board Replacement, Disconnect the USB board: step 36, image 3 of 3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. PlayStation 5 LED Board Replacement, Remove the left faceplate: step 37, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the left faceplate: step 37, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the left faceplate: step 37, image 3 of 3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  38. PlayStation 5 LED Board Replacement: step 38, image 1 of 2 PlayStation 5 LED Board Replacement: step 38, image 2 of 2
    • Remove the left faceplate.
  39. PlayStation 5 LED Board Replacement, Remove the screws: step 39, image 1 of 1
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  40. PlayStation 5 LED Board Replacement, Remove the case: step 40, image 1 of 3 PlayStation 5 LED Board Replacement, Remove the case: step 40, image 2 of 3 PlayStation 5 LED Board Replacement, Remove the case: step 40, image 3 of 3
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
  41. PlayStation 5 LED Board Replacement, Remove the middle panel: step 41, image 1 of 2 PlayStation 5 LED Board Replacement, Remove the middle panel: step 41, image 2 of 2
    • Lift up to remove the middle panel from the case.
  42. PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: step 42, image 1 of 2 PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: step 42, image 2 of 2
    Buy
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED board ribbon cable.
  43. PlayStation 5 LED Board Replacement, Remove the LED board screw: step 43, image 1 of 1
    • Use a Phillips screwdriver to remove the 6.5 mm-long screw securing the LED board to the middle panel.
  44. PlayStation 5 LED Board Replacement: step 44, image 1 of 2 PlayStation 5 LED Board Replacement: step 44, image 2 of 2
    • Remove the LED board.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
4 other people completed this guide.
Robert Boyd
26,693 Reputation
94 Guides authored
2 Comments
where can I buy a replacement light board?
rot253 - Reply
If you are in the UK, they are sold here:
https://consoletherapy.com/store/genuine...
James H - Reply
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 262
All Time: 7,107
