PlayStation Start and Select Buttons Replacement
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: step 1, image 1 of 1
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: step 2, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 2, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: step 3, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 3, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 3, image 3 of 3
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: step 4, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 4, image 2 of 2
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: step 5, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 5, image 2 of 2
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: step 6, image 1 of 2 PlayStation Start and Select Buttons Replacement: step 6, image 2 of 2
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: step 7, image 1 of 3 PlayStation Start and Select Buttons Replacement: step 7, image 2 of 3 PlayStation Start and Select Buttons Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the rubber buttons with a pair of tweezers.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,647
